Ok, 405 1.9 Injection , runs really well except at high speed .. go over about 75 and it heats up and the big STOP light comes on. Rad is full of water and the stat is fine (rad gets nice and hot as do the pipes). Checked the cooling fan and its doing nothing. Fuses all ok... Haynes manual says to check the fan you need to short out the sensor on the rad, if it doesnt run then get a new one. Great BUT the haynes manual says take the connector off and short out the two pins and guess what ? there are two connectors , on half way up on the left (facing into the engine bay) and one at the bottom on the right and they both have 3 pins ! Anyone got any suggestions of how I can test the fan before I rip it out and replace (a dirty job that I would like to avoid!)
Also got the old warm air to the windscreen cold air to the feet problem that a lot of others seem to have...going to pull the heater apart at the weekend and see whats what !
405 Cooling fan how do I test it ?
PowerLee
bigdods
Thx for the input....the connector does have 3 wires, but two are red and one is yellow. As this is a single fan model I assume the second red cable would be for the other fan if it was fitted. Anyway, I shorted pins 1 and 3 (red and yellow) and the fan worked (hurrah!). Put a meter on the thermostat and that was switching too. So it had to be dirty contacts (even though I had alreay cleaned them once). So got to work and gave all the contacts a thorough clean and degrease, put it all back together and everything works a treat
Phew !
Now if I can just get the heater working.....
Homer
- x 16
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by bigdods</i>
I think you may have an airlock. At 75mph it shouldn't matter if the fans are working (unless you are towing a caravan), there should be plenty of airflow through the rad without.
PowerLee
Hi
You do know that you dont get any air flow through the top grill between the lights.
If you do a lot of high speed driving or towing, take the grill off 2 x 10mm bolts & 2 x cross head screws & the clip for the safety catch.
Remove the grill blanking plates & get a lot more air flow to the top of the rad.
bigdods
- x 1496
Cooling fan has no effect above about 30 mph. So, you either have a problem with the cooling system, or the warning light is faulty.
Once you have changed and bled the fluid, if the fault is still present I'd look for the bottom of the rad being cold (silted up), the thermostat not opening fully, or the water pump operating below par.
bigdods
Homer
- x 16
Where were the two bleed screws?
I would expect one near the thermostat housing, one on the input to the heater matrix and one on the rad (though my Cit doesn't have one on the rad).
You might have to cobble something together to get the water level high enough to push it up to the top bleed screw, often header tanks aren't high enough.
PowerLee
Homer
- x 16
KRISKARRERA
