2013 DS5 Sport drivers door mirror not extending fully
Cupra to DS5
x 4
Unread post by Cupra to DS5 »
Hi
The drivers door mirror on my DS5 has stopped extending out fully when you open the doors
Can this be manually extended any way to get it out to the right position
Didn't want to force it and break something expensive
I've tried moving them in and out using the adjustment stick for the mirrors on the righthand side of the dashboard but no joy.
Any tips as have to drive back from Alton Towers later 👍🏻
x 6956
Re: 2013 DS5 Sport drivers door mirror not extending fully
Just manually put it into position - it's designed to allow this (as in a case where an oncoming vehicle can knock it out of position. You'll find it will be able to swivel a full 180 degrees, so don't panic about it.
Try retracting and opening the mirrors several times later to see if it reinitialises, but if not just manually fold it or open it.
Cupra to DS5
x 4
Hi Marc
That's great thanks
Was hoping that would be the case but didn't want to go gung ho at it! 😎😂
I'll give it a twist 👍🏻
