Air Temperature Signal
Air Flow Sensor Power Supply
Intake Air Pressure Sensor Power Supply
Air Inlet Flowmeter Signal
Air Flow Sensor Earth
Thank you very much
Thanks a lot! One last question, what voltage ranges (within normality) should pin 5 give from earth?GiveMeABreak wrote: 24 May 2023, 10:52
Pin (1) 1341: air temperature signal
Pin (2) 1336: air flow sensor earth
Pin (3) Unused
Pin (4) 1337: Air flow sensor power supply
Pin (5) 1333: inlet air flowmeter signal
Pin (6) MC11C: earth mc11
OK. don't worry. my problem is the following: my 206 gives error P1505, I removed the airbag control unit and it continues giving the error, very rare... the case (I have not explication) removing the flowmeter connector the error P1505 disappears and the car works perfectly . I want to override pin 5, it will give me an error on the ECU, but it won't give me an error on the panel and it will let me turn on.GiveMeABreak wrote: 24 May 2023, 11:53 There's not a lot of data specified for this vehicle being a 2002 model, so can't help with that.
