DS5 2014 RT6 problem-
This unit is the eMyWay system, also referred to as RT6, RNEG2, or WIPNAV+ for the Peugeot platform and made by Magneti Marelli.
Main Features: The eMyWay colour satellite navigation has high resolution mapping, Bluetooth Telephone & Audio Streaming supported profiles, USB support for Media files & CD
junkru11
Unread post by junkru11 »
Hi. Im from Estonia i have read lots of RT6 threads here but not found solution to my problem. Ihave DS5 and i bought the original SW update CD from dealer cost 18.- eur. I started the update. Screen flached 2 time and then aperared... Preapering the update... And nothing more it stayed like this 1hour. It apears the cd just was whirl there. Igot the cd out but now the radio and screen not working. Please can somebody give me link with SW 2.77 that i can but it to USB and try then.
Thankyou.
x 6945
Re: DS5 2014 RT6 problem-
I've sent you a Private Message.
I don't have these as a zip file, but if your CD is damaged, then the link I have provided will allow you to download the image file (ISO), from which you can mount on your PC and extract the files to a USB.
junkru11
Same thing..it does something..but remains...Prepearing update...and stuck.
x 6945
Then your internal MicroSD card is probably toast and you should probably have a read of this post:
viewtopic.php?t=63227
junkru11
Hi. I changed the internal SDcard. And then the SW instalation finished. All working ..radio..bluetooth and rear camera. But sometimes if i put car to reverse gear the camera picture on screen starts and then radio does reset. It happends only in rear gear. Are there something wrong with camera or the 2.77SW does not work properly.?
x 6945
You may want to try with V2.86 as you have V2.77 installed. My info suggests that DS5 vehicles (CAN2010) with V2.77 already installed will take the V2.86 upgrade without having to reconfigure the system.
If you are going to try this, do take a mirascripts backup now of the user files (as per the replacement guide), but don't restore these back after the 2.86 upgrade unless you need to. You may find 2.86 fixes the issue.
junkru11
Today i drive like 55km and radio did like 6 times restart ...randomly...sometimes after 10min sometimes 15min...but can yo PM me the latest SW...i put it into usb.
junkru11
Thankyou wery much. Now radio is ok and working.
x 6945
No problem.
