Diagbox Injectors Delphi Dispatch 2.0 DW10FE
hybriduc2
Unread post by hybriduc2 »
Hi when install installing replacement injectors
In these newer vans , Diagbox asks for postion 2 eg ignition on but engine not running , go into pack repair put in 20 digit code hit the button eg OK verify and codes vanish from the boxes ?
Does injector coding on these engines require the
Engine to be a certain temperature? Before coding ,
Any help appreciated, cheers marc
Diagbox v9.91
x 1061
Re: Diagbox Injectors Delphi Dispatch 2.0 DW10FE
Unread post by wheeler »
Are you doing each injector individually or the all 4 option?
I remember having issues a while back where i had replaced all the injectors & was using the option where you can do all 4 at the same time, it just wouldnt accept the codes. When i went in & done them individually the codes were accepted no problem.
hybriduc2
Thank will try cheers marc
