My DS3 stop charging after a month of driving, it was working beautiful and then when I plug it in it flash green starts to charge and then stop and the dash board says its fully charged but I only have 10% battery left.
I changed the charger and that did not work. everything else on the car works.
It retries to start charging twice before it goes full red and shut off.
DS3 charging issues
- x 6945
Re: DS3 charging issues
Assuming you're using the correct charger for the output type, then a red fixed light would suggest a malfunction. In this case it would need a specialist like DS Automobiles to look at it.
AceB
Yes a red fault light is the end result.
It will have to be done remotely as no DS Auto in my area.
Can you recommend a remote operator? we have a Diagnostic tool that can be accessed online.
- x 6945
Unfortunately not, I'm sorry.
napping
- (Donor 2021)
- x 13
How old is the battery?
AceB
car has on 3000 miles its a new car.. 2022 surly not a battery issue
- x 1939
If it's that new then surely the car is still under warranty?
AceB
Yes but to far to return to any DS Auto
AceB
At this point I need help identifying the issue and getting the part or doing an upgrade, warranty is the lease of my concerns
- x 1939
What error messages does the diagnostic give? Give the codes as well as the description.
AceB
1.U1F40 Fault: Absence Of Communication With The Battery
Charge Status Control Unit
2.U1FA0 LVDS Response Time Incorrect (LVDS : Low Voltage
Differential Signalling)
AceB
don't think #2 is relevant as it is related to touch screen
AceB
Where is the The Battery Charge Status Control Unit located??
- x 6945
It is connected to the negative battery terminal wiring, just before the clamp.
