I've had a particle filter additive too low message appear on my 2012 Peugeot 207 VF3**************[VIN obfuscated, can be read by forum staff] DAM 1289082
I've got access to Diagbox 7.57 and lexia 3 as I installed and enabled a cruise control stick
Having looked up the part number: I think its 1500 RZ replaced by 96780336 80. Which is powerflex
My question:
On searching this part number I find two different sizes 1.1L and 1.7L. Which one should it be. I read that the car only knows how much additive is left based on calculated usage. So when I reset it how much does the car think it has?
Any advice?
207 Particle Filter Additive
- x 6955
Re: 207 Particle Filter Additive
It's a 1.1 Litre pouch - the other seller is probably using a stock photo as it's not 1.7litre for this part number.
You replace the pouch and reset the additive ECU in Diagbox. You may find the option in the repair menu - just look for the relevant section. It may need priming too.
