Citroen Berlingo Fusebox
Berodesign
New User
Unread post by Berodesign »
Hi everyone
The fuse box, what are the codes that is printed on the sticker... how many must match up to the replacement fuse box?
It says on mine...
Siemens U118470005 K
BSM-B5
0 / 10125 / 570870749 / 07278
9650618280 - 00
Made in Tunisia
I get all to match up except for the 570xxx part...
Please help! :)
x 3306
Re: Citroen Berlingo Fusebox
Hi, and :welc: to the Forum. As far as I am aware the number beginning 96 MUST match (as this would be the PSA part code). However, it might be worth waiting for somebody with more knowledge to confirm that.
x 6957
Use the international code: 9650618280. If that's what you have on your existing unit then that is what you need to replace it with.
