Another one!
Marlowboy
Another one!
Unread post by Marlowboy »
Hi all, just joined, hello! I recently purchased a 2011 RCZ 200 bhp needing a bit ( lot ) of love! My local Garage, a Classic Car specialist tried extremely hard to put me off buying one, Head Gaskets, Timing Chain issues and Oil Leaks amongst many other things, they failed, I love a challenge! I’m in Buckinghamshire and would like to know if any member has a good Diagnostic machine they would use on my car as the Cooling Fan is on when ever the engine is running and we can not get any Codes. I would put some photos up but my knowledge of I.T. leaves a lot to be desired, it’s an age thing!
x 6947
Re: Another one!
Hi and welcome.
Have a look at our list of members who have offered Lexia / Peugeot Planet / Diagbox Diagnostics help if you haven't already seen it - link below:
At the end of the list is a link to a Google Map, showing the geographic locations of members and details. Just use the Private Message or Email links on the member's profile to contact anyone suitable.
List of Lexia / Diagbox Owners with Kits Offering Help
Bear in mind, although we update the list as often as we can, not all members are active on the Forum all the time, so it may take a while for a reply.
Marlowboy
Re: Another one!
Thank you for your reply, as mentioned, IT is not my forte! My nearest guy on the map is DickieG but I cannot see how to contact him, any help? Thank you!
Marlowboy
Re: Another one!
Think I’ve cracked sending a PM, we will see!
Armidillo
(Donor 2022)
x 274
Re: Another one!
Unread post by Armidillo »
Hi Marlowboy - I don't have an RCZ, but have you tried turning the AirCon off? All these PSA cars run the radiator fan(s) at low speed while the aircon is switched on.
Marlowboy
Re: Another one!
Hi, yes, I’ve tried with Air Con off, no difference! Changed Temperature Sender, an interesting “ little “ job as well again no difference. M trying to get the Codes read with a good Peugeot reader.
x 2003
Re: Another one!
Unread post by Stickyfinger »
I think DickieG has gone from Citroen ownership now.....
