I have a N reg Xantia 1.8 non ABS model. If I am going down hill and apply the brakes and keep my foot at the same place the brakes will come off then come back on (kanagroo braking). This happens in the last 10mph of slowing down. The brakes also are very vicous they have no feel in them and are not progressive. They do However stop you. The problem is in gentle braking. I have replaced the pads and disks and its had a main dealer service. Could this be caused by a faulty Brake control valve?
Xantia brakes come off then on again
- JamesQB
- My Cars: Citroen Xantia 1.8 - I miss this car a lot.
- x 5
My Xantia has the same symptoms. Very annoying and bad for my neck. Accumulator seems to tick too often and moreover, it ticks like mad (every second or faster) when the car height is being adjusted to a higher level. Sometimes it isn't quite so bad, but it always ticks a bit too madly when the car's rising...
Perhaps accumulator sphere in mine...?
When I bought my Xantia just over 12 months ago my brakes behaved like this, my accumulator was ticking at 30 sec. intervals. I changed the accumulator and this improved the brakes quite a lot, but they were still not perfect, if I did the Citerobics the brakes were then fine for a couple of days, I then put Hydroflush in cleaned the filters and susequently replaced the Hydroflush with LHM, the brakes have been fine since I did this.
