Exhaust temperature sensor wiring problem
darbuck
- x 289
Hi all, I just discovered I pulled the exhaust temperature sensor connector apart when I pulled the engine. There are two black wires is there any way I can check which one of these is which without removing the sensor. Any help would be much appreciated?. If there is a wiring diagram available it would help?
Darren
darbuck
- x 289
Re: Exhaust temperature sensor wiring problem
I am going to apply heat to the exhaust using a heat gun and measure voltage generated this should help me identify the signal wire and ground. Am I correct in this assumption.
Darren
KennyW
- x 165
Darren,
How much of the wiring can you see as the numbers on there will tell which is which.
I'll have quick check on sedre and see if I find your model.
Otherwise Marc will get you the wiring diagram for your car through the chassis number.
Kenny
PS Found the following numbers for 2 pin black plug for down stream exhaust sensor which goes directly to the main engine ecu 1274/1275.
But I would wait on Mark confirming this or otherwise.
Worth having a look at this link viewtopic.php?t=59872&start=15
Kenny
C3 1.4 petrol (SWMBO)
darbuck
- x 289
Thanks Kenny, I can't see any numbering on the wiring harness. The plug is brown but I doubt it makes a difference. It would be helpful to confirm one is signal and the other is ground.
Darren
KennyW
- x 165
From the wiring diagram I looked at it was input and output no earth ,so I presume it will be signal that changes with temperature.
Kenny
Kenny
ozvtr
- x 257
It will be a thermistor. A resistor whose resistance varies with temperature.
As the two wires are the same colour the device is not polarized and it is neither connected (directly) to a power supply nor ground. It will only be connected directly to an ECU. So it won't matter which way around the wires go.
darbuck
- x 289
Ok thanks lads that should make it easier just put a new connector on it so
Darren
