Hello! And help!! Gear box video
alexstudly
Unread post by alexstudly »
Peugeot expert 2.0hdi gearbox noise with strange noise.
Problem started and went very quickly, it had an extremely loud noise and then stopped completely, garage says dual mass fly wheel, but itsdriving absolutely fine now.
Video attached.
x 6955
Re: Hello! And help!! Gear box video
If you have a YouTube account, upload your video there, then paste the link into your post.
As it stands you haven't provided a link.
alexstudly
Ah thanks, video below
Alex
Reason: Video link
x 6955
Doesn't sound good and I wouldn't let it idle like that or you cause more damage.
It could possibly be that the DMF has or is starting to brake up - likely if the clutch was replaced without also replacing the DMF as they generally won't last a second clutch.
This one doesn't sound as bad as yours:
The only way to check is to get it on the ramp and see if it is obviously damaged (loose when moved up and down), otherwise it would need taking off to properly check, but when they start to go - and if they break up they can damage the clutch and crankshaft components. Also as it is slightly dissipating when the clutch is depressed this may be another clue.
