Hi, I have a ds3 1.6 diesel in which the adblue injector needs replacing as its showing signs of leaking. I've looked online and it looks simple to replace, however once the new one is installed do you have anything with the cars electronics in order to accept the new part?
Thank you.
Ds3 Adblue injector
- x 6945
Re: Ds3 Adblue injector
There is no coding, but you must check that there is no pressure in the urea circuit. You do this with a diagnostic tool (Diagbox) to release the pressure in the hydraulic system if nececessary.
ian391
Thank you very much for the feedback.
