C5 II 2.0 16v Break with ABS/ESP/depollution error
Morten
Unread post by Morten »
got ABS/ESP error where warning light is on. In addition it has caused the directional headlights not to work properly and got a depollution error light. I have recently replaced calipers front, wheel bearing rear, ballbearing rear arms where rear callipers was removed. Changed brake fluid and bleeded the system. Car worked for 5k km and then I got the error. Tried to replace battery with no change. Got an Autel MP808Z-TS scanner and got quite a few error codes. Have removed those that is not related to ABS/ESP error (like parking sensor and lane assist errors). Question is where it is most likely to find the error(s).
2005 C5 II Break, 2.0l 16v 140hp
Error codes:
Anti-lock brake system -- ESP_MK60 ( 1 DTC )
C1135 Steering wheel angle sensor signal Internal Permanent fault
Suspension -- SUSPENSION_ECOTECH ( 1 DTC )
U1205 No communication with the steering wheel angle sensor incorrect value received Permanent fault
Power steering -- GEP ( 1 DTC )
U1205 Steering wheel rotational speed information incorrect value received Permanent fault
Directional headlamps -- PROJECTEURS ( 1 DTC )
U1205 Dialogue with the steering wheel angle sensor incorrect value received Permanent fault
Thanks,
Morten
x 6957
Re: C5 II 2.0 16v Break with ABS/ESP/depollution error
You have an error in your VIN - it's one digit short.
Have you done any work concerning the steering wheel - or removed any stalks or controls on the unit there? This contains the steering wheel angle sensor and looks to be faulty whether the unit itself is out of calibration (which will be the case if removed), or there is a fault on the data network linking it to the ESP ECU.
When you have corrected your VIN, do also include the other fault codes as sometimes faults can be triggered by other problems that may not be obvious to some.
Morten
See if this is correct.
Morten
Here are all error codes:
DTC Description Status
Lane departure Warning system -- AFIL ( 2 DTCs )
FCF6 Communications fault on LIN Permanent fault
8CE5 Sensor number 5 information no signal Permanent fault
Passenger's door module -- MDP_PASSAG ( 1 DTC )
FC0E Door mirror heating output Permanent fault
Parking assistance -- AIDE_STAT ( 2 DTCs )
FBC7 Internal rear left hand sensor Permanent fault
FBC3 Inner front RH sensor Permanent fault
Radio -- AUTORADIO ( 1 DTC )
F905 Auxiliary audio inputs no. 1 Permanent fault
Air conditioning -- CLIMATISATION ( 1 DTC )
F702 Passenger compartment humidity sensor Permanent fault
Morten
GiveMeABreak wrote: 24 Apr 2023, 11:12 You have an error in your VIN - it's one digit short.
Nothing is done with the steering wheel or controls. Replaced calipers and handbrake cable with guides and have 10K+ km on the meter after that.
According to the scanner, the steering wheel is calibrated. Tried to re-calibrate it but it stopped.
x 6957
Unfortunately most of those codes are not coming up as valid, so you didn't use a Lexia by the looks of things.
But if I recall there is little available from Citroen on these older Petrol engines fault code wise, with little or nothing.
All I can say is that from what you have listed above is there is a fault on the LIN (Local Interconnect Network). The LIN connects some equipment together on a network and if there is a problem it can affect information to and from ECUs.
There seems to be a fair few issues from Parking assistance, AFIL, Directional Headlamps and of course the Steering Wheel Angle Sensor.
I would check to make sure you haven't knocked a wiring connection / plug anywhere where you were working. Also make sure you haven't spliced into any wiring for aftermarket equipment or fitted anything recently that may be interfering with the network.
I wish I could be of more help, but as I said on this engine there is very little data on the fault codes provided by Citroen.
Morten
GiveMeABreak wrote: 24 Apr 2023, 19:03 Unfortunately most of those codes are not coming up as valid, so you didn't use a Lexia by the looks of things.
Thanks for your effort and help.
Can the replacement of rear wheel bearing play a role in this? Or maybe rear ABS sensor have got a hit when removed ? Had one incident with ABS/ESP light after i replaced wheel bearing, but it disappeared. Just guessing. Will start to look at wiring. Will download wiring layout.
Thanks,
Morten
x 6957
Normally a faulty wheel speed sensor will give a specific fault code for the specific wheel, so I'm not confident that would be the issue here. Further, the wheel sensors are not multiplexed themselves - but provide data to the ESP ECU that uses CAN connections to other ECUs.
OlegR
Unread post by OlegR »
I have allmost the same bunch of errors permanently.
I bought the car with the Steering Wheel Angle error, the mechanic, checked, and fixed.... all the wires that are related to ABS. Nothing changed.
The other errors (headlamps, suspension...)are caused by the main one Steering Angle error.
With Lexia it shows me that it's calibrated, but when I'm reading the parameters of the steering wheel sensor, it shows weird numbers. And they are different after I do a new calibration.
Like millions of degrees on the right even if the steering wheel is like 5'.
But mine had a bunch of errors due to the fact that the old owner, once a month connected the battery, let the car run for a few mins, disconnected the battery, and did this for years. The car drove only 200km in 6 years.
I still hope that a proper calibration or few, will fix this.
Morten
Started to look into this case again. Looks like the steering wheel angle sensor does not give any output (degree) when turning the steering wheel.
Car has been scanned with both Lexia and Autel and get the same result. Tried to calibrate, but it failed.
Planning to replace the COM2003 (96611302XT) but before doing this, I would like to check the wiring. Does anyone have a wiring diagram?
In the COM2003 are there any radio transmitters/receivers that need to be reprogrammed if replaced?
Morten
Update.
Steering wheel angle sensor replaced with "new" used COM2003. Replaced the whole unit, and there was no need to reprogram any keys.
Replacing the COM2003 solved the problem with ABS/ESP error, Headlight error. It did not have anything to do with the depollution error. When scanning the Oxy sensors, it reported Bank 1 sensor 2 (P0138) to have high voltage (1.275V). Bought both sensor 1 and sensor 2 and replaced them, cleared the error code and this solved the problem. After replacing sensor 2 the voltage is now dynamically going up and down as it is supposed to do. Voltage now below 1.0 V.
