I am faceing this problem on Renault Trafic 1.6 d 2016 92kw .
Alternator charging 14.8V battery ok and keep showing error ''Electric failure DANGER'' on dashboard
Car works fine.Anybody can give me a solution ?Even to make it disapear for good will be ok.Is annoying
Thank you!
- x 1936
Re: Electric failure DANGER
The first thing you must do is get the car read for error codes.
I don't know much about Renaults but I think that the manufacturer's system is called Clip. A high end system such as Snap-on or Bosch would probably work as well. A €20 Ebay special will not do.
