306 Cambelt
r_306_XSi
306 Cambelt
Unread post by r_306_XSi »
Hi all,
Sent my car to the dealer for a cambelt change & they want to charge me £65 + vat for a new tensioner & bearing ( as existing tensioner bearing is breaking up).
Thing is - I thought the tensioner was changed as part of the cam belt change (and hence in the quoted price) - is this the case?
P 2501
Unread post by P 2501 »
No,not normally. Cambelt change generally means just that - the cambelt only. Quite alot of work to change the tensioner too but if yours is on the way out don't mess about, get it changed. Ask him to check the waterpump and idler pulley while he's in there too.
r_306_XSi
Thanks for the info - just felt like I was getting fleeced. They changed the waterpump as I asked them too (due to other posts here) but just checked over the rest...
woody-som
Unread post by woody-som »
how much do they want for the cambelt, and new water pump.
I need to get the belt changed on mine, and was considering doing it myself, but would prefer to let the people who know do it.
r_306_XSi
Not sure...
Was 350 for a P3 service (plus coolant & brake fluid change) and a Cambelt change with water pump replacement (tho at first they seemed surprised I wanted the water pump changed!)
woody-som
not bad.
I only had the WP replaced once on my escort, it was beginning to leak. I don't usually get it replaced, unless theres a problem, or is there something about peugeot waterpumps on the 1.9TD engine.
r_306_XSi
Posts I read seemed to indicate that "recommended" water pump replacement is at the same time as cambelt replacement, just seemed easier to preventatively get it done
