Peugeot 207 1.4 2007
welly24
I'm looking for ecu pinouts for grey plug on the Magneti ecu thanks
- x 6955
Re: Peugeot 207 1.4 2007
Then you'll need to provide your VIN (please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff).
welly24
- x 6955
Sorry, but that's an invalid VIN you have 18 and it should be 17
welly24
- x 6955
Here you are:
There are 2 Grey 32 Pin Plugs (32V GR) on the engine ECU (1320)
welly24
Thank you il have a look in the morning ,I'm looking for the alternator wiring to ecu the L terminal mine seems to be wired strange I only get 10.5 volts with ignition on 2 volt drop from battery for some reason
- x 6955
Then you'll need the starting circuit here:
