I'm Abdul Im new to french car forum
I own a Citroen grand C4 picasso
I live in Manchester
I need some help with getting acces to diagbox
If anybody has one and nearby no Manchester the help would be appreciated
Thankyou
New member
- x 6947
Re: New member
Have a look at our list of members who have offered Lexia / Peugeot Planet / Diagbox Diagnostics help if you haven't already seen it - link below:
At the end of the list is a link to a Google Map, showing the geographic locations of members and details. Just use the Private Message or Email links on the member's profile to contact anyone suitable.
List of Lexia / Diagbox Owners with Kits Offering Help
Bear in mind, although we update the list as often as we can, not all members are active on the Forum all the time, so it may take a while for a reply.
- x 1943
Re: New member
Abdul has been in touch with me and asked me to help bleed the clutch on his 2009 Citroen grand C4 Picasso semi automatic which I am happy to do. My 7.58 Diagbox should be up to the job but I don't know what's involved. Could you post up the procedure please?
Mods: could you change the title of the thread and move it to the Citroen forum if you thinks that's a better place for it.
- x 6947
Re: New member
He needs to provide his VIN as without that, I don't know which Picasso he has - original or B78, what gearbox he has (piloted or not) etc. etc.
- x 1943
Re: New member
I've messaged him.
8bdu1
Re: New member
Vin VF7**************[VIN obfuscated, can be read by forum staff]
Thanks for the help I appreciate it
- x 6947
Re: New member
Ok, as you have a piloted manual gearbox and clutch, by bleeding the clutch I assume you are referring to bleeding the hydraulic circuit and initialising the clutch engaging point?
These are the procedures from initially depressurising to repressurising and bleeding. I have put them all up for reference, but you'll likely only need the last 2 if you have already replaced the clutch.
Depressurizing the system
Connect the diagnostic equipment to the vehicle’s diagnostic socket.
Switch on the ignition.
Using the diagnostic tool: Select: Depressurisation of the hydraulic circuit.
All the oil contained in the electrohydraulic actuator unit and in the pressure accumulator returns to the piloting actuator hydraulic reservoir.
The piloting actuator hydraulic circuit is no longer pressurised.
Repressurising
Using the diagnostic equipment: Select: Pressurising the hydraulic circuit.
The electric motor of the electrohydraulic actuator unit operates for a few seconds.
The piloting actuator hydraulic circuit is pressurised.
Bleeding the hydraulic circuit
Select: In the diagnostic tool menu:
The vehicle
The RPO no.
Perform the global test.
Using the diagnostic equipment: Select: Bleeding the hydraulic circuit.
The diagnostic tool pressurises the piloting actuator hydraulic circuit, changing through all the gears in order to force air out of the circuit.
Repressurising
The vehicle
The RPO no.
8bdu1
Re: New member
Thanks for all the help from Paul r and give me a break
If the clutch flywheel and slave cylinder have all been changed does that affect the procedure at all
- x 6947
Re: New member
No, it's only the hydraulic actuators that the procedure refers to as these automate the tasks of gear change and clutch operation. The clutch, clutch slave cylinder and flywheel are 'dumb' components. So at any time the clutch has been changed it needs to have the procedure run.
- x 1943
Re: New member
Things have gone quiet with this. I've messaged Abdul but the message is still sitting in the Outbox and he hasn't logged in to here for 10 days or more. Hopefully the problem has been fixed locally.
