hi i have rescently bought a 306 xsi it was running fine until the other day when it lost power i have put this down to the fuel filtter not been changed at all i changed and its running fine now apart from the cooling fans are running all the time are these connected or just coincidence and how do i rectfy this problem.
as i said i have just got the car and theres no book with it how do you change the code
thanks scraff
cooling system and keypad code 96 306
PowerLee
Hi
Check the temperature sensor on the back of thermostat housing, The fans will run if the sensor is unplugged or faulty.
Note: there should be 3 different sensors, 1 for the ECU, 1 for the temp gauge & another 1 for the STOP & High temp warning light.
Have you got ac fitted? Is it switched on? this will cause the fans to run aswell.
To change the Keypad code do this:
Ignition on, red keypad light on, input old code.
Green light comes on, Press button C, Keypad beeps once.
Enter a new 4 digit code slowly.
Press button C again, Keypad beeps 4 time & green light flashs 4 times.
Code is now changed.
Note: the keypad will remember BOTH codes old & new, untill the next time the keypad is used & you input a code.
EG: you forget you have changed the code ( Done this myself a few times, lol )& put the old code in, it will let you do this ONCE ONLY!
So if you change it, lock the car & come back later & put the new code in, thats the only code it will remember.
There is also SERVICE mode which lets you let someone else use your car with a different code, eg Friend or garage.
To set this:
Stick your 4 digit code in, green light comes on.
Press button S & keypad beeps.
Enter a different 4 digit code slowly & press button S agsin.
Keypad beeps 6 times & green light flashs 6 times.
Keypad will now respond to both codes.
To turn service mode off all you have to do is enter your own 4 digit code.
To set this:
PowerLee
