Caliper guide pin gaiter
froggy
(Donor 2026)
x 4
Unread post by froggy »
Hi, I need to replace the guide pin gaiter on my S2 Xantia. Can I replace the gaiter in situ or will I need to remove the caliper? Thanks in advance Terry.
Terry
Xantia TD lx series1 SORN
Peugeot 306 meridian [ the boss]
Xantia HDI Forte 1997 CC
x 8457
Re: Caliper guide pin gaiter
The caliper will need to be removed Terry...
froggy
(Donor 2026)
x 4
cheers Jim
Terry
froggy
(Donor 2026)
x 4
how do you get the new gaiter back into the caliper ? I am a bit worried about damaging the new gaiter if I try and drive it home with a hammer and piece of wood! thanks Terry.
Terry
x 8457
Once all cleaned up it should be a fairly easy press fit Terry... Strong fingers should do it...
froggy
(Donor 2026)
x 4
cheers Jim
Terry
