Webasto automatic start and smoke
Fin50
Unread post by Fin50 »
Dear all
Car: C5 X7 (2010), 1,6HDI
Problem: Webasto (Thermo Top Evo, I suppose?) --> unreliable start-up, and a lot of white smoke for first 5 minutes after cold start.
Here is some contribution:
How to disable automatic startup of the smoke generator (in my case at least):
- open up Diagbox (I had version v07.57)
- once you are connected to the car, choose "Repair"
- from Global Test list select "Injection/Ignition"
- under Injection/Ignition, click "Configuration"
- choose "Configuration with displaying of the parameters" --> "Manual configuration" --> "ECU downloading"
- try and find "Additional heating". Click the droplist (arrow down) on the right side of current heater setting
- IMPORTANT: make a not of your current setting, as you may later want to return it as it was
- IMPORTANT(?): You MAY be able to do harm to your car by changing values under "ECU downloading" --> do not change anything randomly
- change the setting to "NO ADDITIONAL HEATING"
- confirm by clicking "two gears"-button on the bottom right corner of the window
Now the smoke generator will NOT start every time you start the car for 1 or 2km driving.
You can still start up the Webasto (when needed) with your remote control (Webasto telestart T100).
And here is a question:
Does anyone have suggestions what should I do to repair the after-start smoking issue, and unreliable startup? I'm not willing to take it to Webasto dealer = too much €€€ for a student.
My guess is there is a lot of soot inside combustion chamber --> open and clean it!
Are there some components I should expect to replace to this Webasto at the same time (after 13 years of hard driving and low maintenance)? Gasket set, of course. Something else?
Thanks!
Pekka
citroenguy
(Donor 2021)
x 75
Re: Webasto automatic start and smoke
Unread post by citroenguy »
Webastos are worse, usually need a lot of parts replaced.
Just cleaning wont help, needs at least burning chamber and glow plug replaced.
Service kits might be available?
I have various repair handbooks and wiring diagrams for C5 mk1, Xantia, XM, Berlingo and C3 mk1.
I have Lexia/Diagbox (Sweden) and Servicebox/sedre
Fin50
Hi
Thanks for you opinion/warning, citroenguy. As we got no other comments, and I'm stuck with what I have, I think I will just open the heater to see what's inside it.
It won't get any worse, as it is anyway useless during colder days (-15C or more) due to unreliable startup. I expect to find a lot of carbon buildup, possibly leaky fuel nozzle without proper atomization, and maybe somewhat dead ignition plug (incandescent finger or something like that - sorry my non-native english).
I will post my observations here once I'm done (in month or two, maybe).
