Ds5 front door glass replacement.. instructions
Megliam10
(Donor 2021)
Unread post by Megliam10 »
Hi folks
I have to replace the passenger front door glass.
Anyone got a step by step for me to do this. I have a replacement glass.
Any help gratefully received.
x 6960
Re: Ds5 front door glass replacement.. instructions
The front door trim panel, sealing sheet and speakers have to be removed, door glass lowered, remove horizontal weatherstrip on door where glass is lowered,. In the area where the speaker was, and after the glass is lowered, you will see a fixing holding the window. Remove away from the stud (it can only slide one way).
The glass then has to be rotated carefully from left to right, so that the sharp angle is vertical, and then removed vertically out of the door through the door window aperture.
You'll need new sealing components of course or water will get into everything.
Megliam10
(Donor 2021)
Many thanks
