Connector Question
rossnunn
Connector Question
Unread post by rossnunn »
In my fiddling I found a red connector by the fuse box of my ZX. it has two green wires so with a bit of investigation it goes to the same multiplug as the ISO for the stereo.
What is it?? somesort of diagnostic plug??
NiSk
Unread post by NiSk »
Control wire for electric aerial? or pilot wire for remote amp? If you check which pin on the ISO it goes to, I can check on the ISO signal schematic.
//NiSk
NiSk
Hi again Ross - the block schematic I have is available on:
http://www.clarion.se/support/faq/iso.htm
It's in Swedish, so the pin outs are:
A-1 'phone mute
A-2 12V permanet
A-5 Electric aerial / remote amp
A-6 Seperate radio lighting
A-7 12V via ign. switch
A-8 Ground
B-1 RH rear +
B-2 RH rear -
B-3 RH front +
B-4 RH front -
B-5 LH front +
B-6 LH front -
B-7 LH rear +
B-8 LH rear -
//NiSk
