Citroen c4 grand picasso 1.6 hdi turbo problems
Carlp123
Unread post by Carlp123 »
Hi I a citroen c4 grand picasso 1.6 hdi 2009 model with a fult code p0299 I have checked all pipes and changed the pressure boost solenoid and I have checked the turbo actuator and still get same fault code car has lost a lot off power slow picking speed up and soon as I go up small hills speed drops dramatically even on motorways plz can anyone help !!! As car is used to get my disabled wife around
Carlp123
Re: Citroen c4 grand picasso 1.6 hdi turbo problems
Hi I have sorted the problem it wat the tee junction on the vacuum pipe where it joins with the break servo that was blocked causing the issues I had
x 1941
Unread post by Paul-R »
Excellent work. Did you discover what the blockage was and where it had come from?
Carlp123
Yes the the vacuum reservoir had come off and melted on the exhaust so had to replace it
