Hi folks
Trying to work out the name of a part
Under the bonnet 1.4hdi
lives under a metal cover with a belt the pulley which belt goes around is making a whirring sound
Nemo parts
- x 6945
Re: Nemo parts
Possibly the accessories / alternator belt pulleys or the tensioner roller or the timing belt kit. When was the timing belt replaced?
ohspecial1
Re: Nemo parts
to be honest i have only had it 9 months so i am unsure
it should be replaced every 10 years i believe
https://www.usedcarpartsuk.co.uk/citroe ... -2008-2017
have enclosed a link lives under the 9 o clock position
- x 6945
Re: Nemo parts
Impossible for me to say on a Forum as you can appreciate. It needs physically investigating to determine where the issue is.
- x 1055
Re: Nemo parts
Can you post a pic of the actual part you mean or circle it on the picture?ohspecial1 wrote: 18 Mar 2023, 18:42
From your description it sounds like you could mean the power steering pump, if it sounds noisy first thing to check is the steering fluid level.
ohspecial1
Re: Nemo parts
Hi have added it
when i look under the bonnet it lives under the metal housing looks like a pulley or something that has a belt
- x 1055
Re: Nemo parts
The part that the tip of the red line is touching is the engine mount. There are no moving parts in this so wouldn’t make a whirring sound.
If you mean the part just before the end of the red line thats the steering pump.
ohspecial1
Re: Nemo parts
Hi
The item that lives under that pipe is like a metal housing if i have a look there is a belt and 1 or 2 pulleys/wheels if that makes sense
Im just wondering if its just a noisy pulley
Power steering doesnt whine or nothing
