Hello all
I bought shifters paddle for my Peugeot 207, they are already mounted and connected but still doesn't work. The car is prewired with this features.
Can you provide me please the wiring diagram for this paddle shifters or any support in order to fix this personal issue.
Or, is mandatory to activate this option in Ecu/BSi?
Thank you in advance for yours support!
shifters paddle Peugeot 207 automatic gearbox
cosmin cristache
- x 6954
Re: shifters paddle Peugeot 207 automatic gearbox
These are NOT for use with fully automatic AL4 gearboxes, only for the piloted manual gearboxes, so you won't get it to work, regardless if the pre-wiring is there.
cosmin cristache
This paddle will not work when the gear shift is in +/- position, not in D (drive mode) ?
- x 6954
These are not designed for automatics with the standard shift selector and were never fitted as such.
cosmin cristache
Ok. Thank you!
