Hello ive been looking at getting a C5 X7 and as an hifi person id like to replace the headunit with something supporting android auto and bluetooth etc so i want to ask is this possible and if it is how should i go about it.
Thanks.
Headunit replacement on C5 X7
- x 6950
Re: Headunit replacement on C5 X7
I can't provide any help on this personally, as I only support the original head units. You should be aware that RD4 models provide access to some vehicle configuration options, so it is highly possible that you may loose access to this if you do replace it with an aftermarket unit.
Your best bet is to consult the seller of any proposed unit to ensure you get the correct CAN interface and for fitting instructions.
SuburbanKino
Hey there.
Alright ill look in to that but i may just think about getting a dsp and amp for the door speakers and adjust the sound that way to keep the original head unit etc in place thanks for the help though
- x 6950
No problem - it's just so you are aware.
