Whilst jump starting the car with the assistance of a 'Helpful Friend', my attention lapsed for a mo and I didn't notice he'd attached the jump leads the wrong way round!
There was a bit of a nasty smell and we both then went to the pub. Have we killed the car or will it just have blown a fuse? I did a quick check, but they all seemed not to have blown.
Any help gratefully appreciated.
Thanks.
2005 Clio 1.2 - jump leads wrong way round!
- x 6955
Re: 2005 Clio 1.2 - jump leads wrong way round!
I guess you will find out soon enough is certain things start malfunctioning or not working. You may be lucky, but the ECUs can be very sensitive this sort of thing.
- x 2941
Our vicar did that but on Hyundai, there was a fusible link by the battery connections that blew. Don't know about the Clio.
This maybe. https://www.ebay.co.uk/itm/301852203936
- x 1445
The sensitive electronic components will be protected by diodes and relays, but the alternator is only protected by a fuse so is the most likely casualty.
Connect a charged battery and see what happens,
- x 1056
At the very minimum you I would think you will have a blown fuse or 2. As said connect a charged battery first & see what happens, If it wont start check all the fuses.
I helped out someone with a Micra a while back that had done this & it had blown three different fuses. After replacing the fuses it was fine.
