Injector leak back test result
darbuck
x 289
Unread post by darbuck »
Hi All, I just ran a leak back test and I have three good injectors the fourth is not returning any diesel. Does this indicate a clogged injector.
Thanks in advance for any advice
Darren
x 2362
Re: Injector leak back test result
Unread post by MattBLancs »
Given how little is in all of them, I'd be tempted to run it for longer. It might not give a different result, but at the moment it could be that it does "leak less" just at present less than not a lot = nowt :-D
darbuck
x 289
I ran it for 3 mins which is the recommended test but there is absolutely nothing coming out of the cylinder 3 injector on leak back, It would explain why I am getting a jammed shut fault code for the no 3 injector. Thanks by the way Matt. I also think it tells me that my valves are good 😃. Not damaged from timing belt being out by a tooth.
Darren
x 2362
Sorry, didn't make the link to the other discussion - yes seems a likely candidate for your new poor running issue.
I think injectors can be cleaned - ultrasonically? I'm not sure if your typical "domestic" type ultrasonic cleaner is powerful enough? Would think cycling the injector on and off would also be a good idea. Am sure I have seen it done (on YouTube most likely - will have a dig)
darbuck
x 289
Ok I have an ultrasonic cleaner it might work. but I also bought a second hand injector off eBay so I will swap out when it arrives I am going to try swapping injector 2 and 3 to see if my issue jumps. What do you think
Darren
x 2362
darbuck wrote: 01 Mar 2023, 21:39 Ok I have an ultrasonic cleaner it might work. but I also bought a second hand injector off eBay so I will swap out when it arrives I am going to try swapping injector 2 and 3 to see if my issue jumps. What do you think
Yes, sounds a good plan. Have you got a set of the copper sealing washers too? Would be best to change those when disturbing at least a couple of injectors.
darbuck
x 289
No I'll order a set now thanks for reminding me.
Darren
darbuck
x 289
Hi lads tried to pull the Injector but wouldn't budge using a slide hammer.
Good news tried starting her and running her and she just started running nice I think the slide hammer freed the solenoid. Code cleared didn't come back so fingers crossed.
Darren
x 2362
Ha ha! Excellent news!
Either "percussive maintenance" or else the threat of violence was enough!
Hope it continues to behave, must be a relief after weighing up potential bent valves etc recently! Well pleased for you =D>
darbuck
x 289
Thanks for your help Matt it really helped. The same to everyone else.
Darren
