Citroen Relay 2.2 HDI 2016 Digital Temperature gauge
Flyinghaggis71
Unread post by Flyinghaggis71 »
Not sure if this has been discussed but apologies in advance
My digital display flashes from 84c to three lines pretty much all the time. The manual gauge sits about right when running temperature is met.
Would it be safe to deduce that the digital sensor may be faulty? Where and how easily van it be located and replaced?
Also struggling to find a secondhand metal pipe connection which sits near the sump plug connecting the two rubber hoses from bottom of radiator to engine rubber hose, if anyone can help there.
Cheers !
Flyinghaggis71
Re: Citroen Relay 2.2 HDI 2016 Digital Temperature gauge
Any ideas out there??
x 3298
Hi, and :welc: to the Forum. I personally cannot offer any direct help, but (with any luck) somebody with commercial vehicle knowledge will spot this thread and respond.
