Hello!
Any instructions to deal with this problem?
I have Lexia and would like to reset Steering wheel sensor but where do I find it in Lexia?
Could the problem be:
1. Fuses?
2. cable break?
3. steering angel sensor?
4. com2000? Exhange?
Can a total reset help? BSI?
What can i Use in Leixa to deal with this problem?
Lexia says it the steering wheel sensor (permit problem) fautlycode... but when we check the stering angel value its -128 in the middle!
2.0 Petrol engine!
Anyone? = )
C5 2006 ESP/ASR fault.. Lexia - Steering wheel sensor?
74anders
- x 6950
Re: C5 2006 ESP/ASR fault.. Lexia - Steering wheel sensor?
Well as it suggests the Steering Wheel Angle Sensor is way off. This can happen if the control unit inside the the steering wheel (Comms unit) is removed / replaced. You can try recalibrating it using Lexia.
Should be located here:
Suspension >
Configuration >
Initialising a sensor of the type: steering wheel angle sensor
Follow the guided procedure, but first make sure your tyre pressures are all ok and you are on flat, even ground before starting.
Suspension >
Configuration >
