Water leak
Mutt-McGee
Water leak
Unread post by Mutt-McGee »
Hello.
I need help identifying the plastic pipe that looks flexible but is actually quite rigid on my 2007 Berlingo van 1.6 75hp diesel. See pics.
It runs under the fuel filter then round the back of the engine under the air filter and joins a fitting where the large ‘U’ shaped hose is. I’ve tried several parts suppliers but no luck as yet.
If anyone knows if this has a specific name or even a part number that would be very much appreciated.
Huskyxantia
x 927
Re: Water leak
Unread post by Huskyxantia »
Comes off the thermostat housing id call it thermostat housing hose outlet one
:-D
Mutt-McGee
Re: Water leak
Thank you. I’ll try a search with that suggestion.
