Dispatch MK1 ECU swop
TeddyMcB
New User
Unread post by TeddyMcB »
Hi All, I have just joined as I need some help please. I have a Dispatch MK1 van with a 1.9 WD8 engine. I believe my ECU is not functioning so I am looking for the connector pin out for the 2 connectors on the ECU so I can check the wiring please . Also if my ECU is dead can I just swop another in or will it need coding. Is there any way to tell if the ECU is working or not? I suspect the ECU it not working because the engine is Diesel Knocking and disconnecting the MAF or the Lift sensor on injector 4 makes no difference. I don't know if I have a Bosh or Lucas Fuel injector pump can any one tell me how to figure that out please? I have no fault lights on the dash but my ODB reader will not communicate with the ECU. I am using a Delphi Code reader connected to a Lap Top.
Thanks in advance for any help.
Teddy
