Hi, I have recently acquired a 2018 Peugeot expert on about 90000 miles.
Not long after I had it, it started going into "limp mode"
here is the fault codes it's bringing up.
I am pretty handy with fixing things but I am unable to diagnose the the problem from the codes, can someone help?
Car Scanner ELM OBD2
DTC report
Selected brand: Peugeot
============1==============
P0426
Raw code: 0426
ECU: Engine control unit
Status: Confirmed
OBDII: Catalytic converter temperature sensor, bank 1 - range/performance problem
============2==============
P2033
Raw code: 2033
Status: Confirmed
OBDII: Exhaust gas temperature (EGT) sensor 2, bank 1 - circuit high
============3==============
U3FFF(FF)
Raw code: FFFFFF
ECU: Engine control unit#3[Archive (inactive)]
Status: Test failed since last DTC clear
============4==============
P2084(00)
Raw code: 208400
Status: Test failed since last DTC clear, Test not completed during this operation cycle
OBDII: Exhaust gas temperature (EGT) sensor 2, bank 1 - range/performance problem
============5==============
P0426(00)
Raw code: 042600
Status: Pending, Confirmed, Test failed since last DTC clear, Test not completed during this operation cycle, Warning indicator requested
============6==============
P2033(00)
Raw code: 203300
Status: Test failed (current drive cycle), Pending, Confirmed, Test failed since last DTC clear, Warning indicator requested
============7==============
P0949(78)
Raw code: 094978
ECU: Transmission control unit#3 / BSI
Status: Test failed, Test failed (current drive cycle), Pending, Test failed since last DTC clear
OBDII: Auto shift manual (ASM) transmission - adaptive learning not done
============8==============
U1118(87)
Raw code: D11887
ECU: Transmission control unit#3 / BSI[Archive (inactive)]
============9==============
U3FFF(FF)
Raw code: FFFFFF
ECU: Engine control unit#4[Archive (inactive)]
============10==============
P2084(00)
Raw code: 208400
============11==============
P0426(00)
Raw code: 042600
============12==============
P2033(00)
Raw code: 203300
