Citroen Relay 2012 Alarm Wiring
egizz983
Hello i am trying to install Clifford G5 alarm into my van but cant find wiring diagrams anywhere , does anybody knows where to get them ?
- x 6950
Re: Citroen Relay 2012 Alarm Wiring
If you want the central locking wiring diagram, post your VIN up here and I'll see if I have what you need (please post your VIN in full without spaces - it will be automatically masked from public view after submitting your post & will only be visible to staff).
egizz983
VF7**************[VIN obfuscated, can be read by forum staff] . thank you sir i need wiring for door sensors and locking . i also need to connect immobilizer so need wiring for ignition as well if you can get that
- x 6950
Central Locking
Injection
Injection
egizz983
where is bsi located if you know ?
- x 1061
Assuming its RHD the BSI is located behind the fusebox panel just above the drivers right knee.
Be aware some of the connections may be covered by a metal bracket held on by shear head security bolts.
egizz983
yes i was looking it there but didt see . i cut out all metal boxing to take it out fuse panel
egizz983
is there are more detail version of diagram . what are all those numbers means ect
- x 6950
Wiring codes on the wires and hardware codes for the equipment. This should be all you need, otherwise I'd suggest an auto electrician if you're having a problem following them.
Most of the hardware codes are on the wiki here:
https://frenchcarforum.co.uk/wiki/Elect ... ring_Codes
These are French of course, so a connector with 2V NR means a Black 2 pin Connector.
3V JN means 3 pin yellow connector.
egizz983
that is the problem there is only one guy who does alarms and he only do viper alarms already spoke to them so i am all on my own now unless drive 100 miles to have it installed . but the wiki you send will help alot tnx
egizz983
just a question what is wire number and how to identify them . or each number represents color of the wire ?
- x 6950
Ignore colours, PSA often change the wiring colours. Stick to the number that is repeated on the sleeve every several inches or so.
egizz983
oh you mean there is actual number on the wire it self ?
- x 6950
Yes. You may need to peel back or unwrap some of the loom tape that protects multiple wires in a bundle to see the wiring codes.
egizz983
i check all wires none of them numbered no markings at all . is there are another schematics or wiki page that relates to colors ?
