HI,
I have a 106 XND (1994). I am experiencing squeaks from the rear wheel area. When the car is stationary and depressed both sides squeak. I have also noticed that squeaks stop for about 3 or 4 days after it has rained.
Any advice would be appreciated.
Squeaky rear
you may find that it could be needle bearings in the torsion bar cross tube (this is where the trailing arm and wheel pivot when the suspension is compressed) they can go dry and wear and cause "squeaking" noises. when it rains moisture can get past the seals to the bearings and act as a lubricant. I ve got a 205 gti which had the same problem. its not an easy job! another possibilty is shock absorber mounts? hope this can help a bit?
