Citroen Berlingo 2.0 hdi 2005 when heated above 70 degrees does not start from the starter
Mikhail kolkov
Unread post by Mikhail kolkov »
x 6946
Re: Citroen Berlingo 2.0 hdi 2005 when heated above 70 degrees does not start from the starter
You may want to check your engine coolant sensor, as if this is faulty it might make the engine ECU think it is hotter than it really is.
