Berlingo Oil level check STT6SPEED PILOTED MANUAL
Egis
Unread post by Egis »
Hello,
Does any one knows, how to check oil level in gearbox 2012, Berlingo 1,6, 92, Bhp. Diesel.
STT6SPEED PILOTED MANUAL. I Have lost I guess, half amount of oil in my gearbox via changing some parts.
Thank you.
x 6946
Re: Berlingo Oil level check STT6SPEED PILOTED MANUAL
Just to be absolutely clear we are talking about the geabox oil and not the oil for the piloted actuators.
Gearbox Oil STT 6 Speed Piloted Gearbox
Quantity of oil to fill after draining: 2,1 ± 0,1 litres.
Quantity of oil to fill after an overhaul: 2,2 ± 0,1 litres.
Oil quality: 75W80.
So in your case you MUST drain the gearbox oil and refill it according to the above as you do not know at this point how much you have lost, so this is the only way to ensure the correct amount is put into the box.
Egis
Marc, thank you for your replay. As you have mentioned, that was gearbox oil.
As I know, there were I drain and fill points in older versions. Today I have moved my car to garage and they said, that there are no fill/level point on this. So we have drained full amount, and refilled.
But it was refilled 1,9 l. only. Do think it might have some problems later on?
Thank you Marc!
x 6946
That's as near I think as you'll get as there will always be a little left in the system. Best not to over-fill it.
