Is there any easy way of telling if ones air con. needs re-charging?
and if it does where is the best place to get it done?
Xantia Air Con
Kowalski
There is a sight glass on the top of the air-con dryer bottle (its in the front drivers side corner of the car next to the radiator header tank / washer bottle / ecu etc). With the aircon running, there should be a clear stream of liquid running past this glass, with no-air bubbles in it. Any air bubbles generally indicates that your system is short of refrigerant.
np
I had mine changed 2yrs ago now.When hot,i have it set at 18degrees,and leave fan on auto.It did`nt seem 2 b very cold,& running it on max cold & fan speed made no difference.No record of it being changed when i got car(4 yrs old)Under bonnet on drivers side at top is the drier bottle/canister,black with sight glass.Checked that as in manual,came 2 conclusion that it needed changing.Also,bottle was very rusty.
Took it 2 a local auto electical place who changed bottle,checked & re-gassed 4 £150 all in.Said that it should b done every 2 years or so,though next time would just need a re-gas at £70.What a difference it made!!Took it 2 Italy that aug,42degrees,worked great!
Still good now.
Have a look in Yellow pages.Some places will do a free check 4 you.Prices vairy.
Hope this helps.
Still good now.
Hope this helps.
np
paranoid
alan s
- RIP 2010
- x 6
I think you'll find they're directly under the evaporator (cooling coil) and someone posted a while back that if the console or one side of it was removed, you can gain access to it and clean it from the top.
Be careful prodding around though particularly in the vicinity of the actual evaporator; doesn't take much to poke a hole in them and that's major drama if you do. Compressed air is as good as anything and mould combined with dust is your most likely culprit.
Alan S
Alan S
paranoid
alan s
- RIP 2010
- x 6
paulstow
For cleaning the drains on many cars ( not had to do this on Citroen yet ) it's often easier to find the drainpipe from underneath the car and use an airline to clean it through.
To keep the seals on the a/c system in good condition and prevent leaks it's best to run the system for a few minutes every week even if it's not actually needed.
Cheers - Paul
Cheers - Paul
Kowalski
paranoid
Kowalski
Bubbles are a sign that there is not enough gas in the system. No liquid is a sign that there is not enough gas in the system. Milky coloured liquid indicates the system is saturated with water.
The reason that you have to run the air-con once a month to 'maintain' it is that when you run the compressor, it lubricates its seals and prevents them from drying out, it also pushes the gas through the drier bottle so removing any moisture that may have collected in an inconvenient place in the system i.e. where it could cause corrosion.
paranoid
alan s
- RIP 2010
- x 6
It gets a bit weird with all these gases these days.
In the days of exclusively R12 it was a case of looking for bubbles as a sign of gas getting low. If it got too low it didn't show anything, just the same as when it's fully charged; that got a bit confusing, but these days all systems using R134a and MP52 drop charge the systems and the sight glass no longer is relevant.
If it's cold as charity, it's working OK. All you have to do is give it a run occasionally so the seal doesn't lift on the compressor, keep the condensor cleaned and watch for qny oil stains at the connections.
Alan S
Alan S
paranoid
