[C5 X7] 3D printed boot-cubby elastic mounts
Guides on how to approach the more common problems experienced by our members.
Please don't post in this forum but link to the threads here where necessary.
Anyone wishing to create a howto please submit to a mod or admin for inclusion here. Subject to being edited.
the-termin8r
x 143
Unread post by the-termin8r »
Sorry if this is in the wrong section.
I got fed up of things falling out of the cubbies in the boot where the battery and CD changer would sit on higher-spec models. So, I designed some basic mounts to be 3D printed that attach an elastic band to the cubbies. The working principle is quite simple, it just clamps an elastic band on either side of the cubby and it allows for custom tension. Installation is a bit of a faff, but it works as intended for me. Figured I'd share the designs here. The folder includes the STL files and a parts list with (UK) links and a basic installation diagram.
Just a few notes:
  • This requires a little bit of drilling of the cubby, nothing complicated or too damaging. I've provided a stencil in the designs. The stencil has a cutout in it, the length of the cutout is 40mm which is also the width of the elastic. This should help you with positioning.
  • For the clamp piece I've included a version that works without heatserts, because I know not everyone owns a soldering iron.
  • If you use the version with heatserts, you shouldn't need the locknuts to keep it together, but it's a good idea to install them to make sure the vibrations of the car don't undo the screws over time.
  • The locknuts are mandatory if you go for the version without heatserts.
  • I printed mine in PLA, time will tell how they deal with summer heat.
C5 X7 boot-cubby elastic mounts.zip
- Rob
My account accidentally got deleted late Dec '23, so if you're reading my posts from then or earlier and they look weird / are missing media, that's why. There's no fix, sorry.
If you're reading any of my posts with missing design files, find them on my Google drive
x 2355
Re: [C5 X7] 3D printed boot-cubby elastic mounts
Unread post by MattBLancs »
It's is interesting that nothing is provided to make these into a useable storage cubby on the X7 saloon - as there's a similar concept mesh basket provided in these positions on the X7 Tourer (estate) - will try to remember to take a picture in the daylight.
Nice resourceful idea, thanks for sharing!
the-termin8r
x 143
Yeah, I'm familiar with the estate ones, I was also wondering why the saloon doesn't have a mesh. I actually tried to source the flush covers for the battery and CD changer, but either didn't search the correct terms or there just aren't any around for sale.
- Rob
x 2355
7568 ZL = Nero mistral (black I think)
Says
https://catalogs.ssg.asia/citroen/?lang ... aWVyPT0%3D
7568zn = morning grey
Note: this is pocket+ mesh , the mesh isn't listed separately on here at least
x 1939
Unread post by Paul-R »
The mesh is crap in the estate. No point having there so why lumber the saloon with the same?
x 2355
the-termin8r wrote: 06 Feb 2023, 21:52 Yeah, I'm familiar with the estate ones, I was also wondering why the saloon doesn't have a mesh. I actually tried to source the flush covers for the battery and CD changer, but either didn't search the correct terms or there just aren't any around for sale.
Sorry I have miss read your post, part numbers above are the pocket plus mesh ones for the estate.
x 2355
Paul-R wrote: 06 Feb 2023, 22:28 The mesh is crap in the estate. No point having there so why lumber the saloon with the same?
Crap: yes,
Better than nothing: personally, think also yes,
Solution (or basis for potential improved solution) for those without access to a 3D printer: yes?
x 6945
Good idea and thank you for sharing the files for the members.
I used these storage areas in my X7 and unfortunately the standard mesh straps came off on one of the cubby holders from holding various things. Not least was a 5 litre container of screenwash that ended up leaking out into the boot and all over my parking assistance ECU which took me weeks to clean up and dry out.
I think I made a repair to mine by removing it and re-attaching it, but your design would provide additional tension and prevent this from happening, especially if going at unsafe velocities!
I've copied this topic to the ' How To' section.
the-termin8r
x 143
Just want to quickly re-add the files as they seem to have been lost when my account was accidentally deleted. I can't seem to edit the OP, so hopefully anyone looking for them will scroll this far down.
[The extension zip has been deactivated and can no longer be displayed.]
- Rob
the-termin8r
x 143
Re-adding the files since zips are no longer allowed. I've put them on my Google drive instead.
- Rob
