Berlingo 2005 HDi2.0
Kristi0205
New User
Unread post by Kristi0205 »
I have probleem. If I start the engine, it works about 5 seconds and just stops, I do not do anything. Engine sounds ok, I checked fuel filter and pump.
Any ideas what is wrong.
Kristi
x 1053
Re: Berlingo 2005 HDi2.0
Unread post by wheeler »
Have you had fault codes read on it? Could be EGR valve stuck open, You could blank it of for test purposes to rule it out.
kingjafad
(Donor 2026)
x 8
Unread post by kingjafad »
I'd be tempted to manually prime the fuel with the hand pump under the engine cover. If it starts and stays running for longer, then there is either a leak between the handpump and the fuel rail (possibly the fuel filter housing) or the tank vent is creating a vacuum and sucking fuel back meaning you arent getting the right amount of fuel upon starting the car (also try priming the fuel via the key - just turn key on (but not start the engine) 3 times - you should hear the whine of the pump priming the lines without the engine running. Then on 3rd go, actually start the engine. If it turns out to be a vacuum in the tank, leave the filler cap off and try again.
