Ok, I've just had my cam and aux belt changed including a water pump as mine was leaking.
fully flushed the coolant system, and refilled with coolant. When i drive with heater off, the temp goes up, radiator fans kick in and the coolant is blown out through the expansion tank.
If I have the car running at fast idle with the cap off there are bubbles coming out from the expansion tank and I think it smells of exhaust. I have a cold so sense of smell not good.
If i replace the cap and leave the car running at normal idle then no problems.
I read it could be the head gasket, but wouldn't that blow bubbles into the coolant regardless of engine speed? I also heard i could have a EGR cooler leak which can do the same thing.
Is there a way to tell? really can't afford the Head gasket change at the moment.
Thank you
407 Sport HDI 2.2 Coolant pressure
vortexco
Peugeot 407 Sport SW 2.2 HDI
Peugeot 307 SW 1.6 HDI
