Cross Referencing Parts
slackgarry
Unread post by slackgarry »
Looking for somewhere i can cross reference Cabin Filters for a little project. Does anyone know of anywhere or other Cabin filter the will fit a C1.
Thanks.
Kind regards
SlackGarry
Black 2008 C1, Petrol, 1KR-FE Engine. aka the GoKart
x 6947
Re: Cross Referencing Parts
They tend to be specific to the heating system used on the vehicle. In your case as the C1 is the same vehicle as the Toyota Aygo and the Peugeot 107, you may have luck with one of them, but no guarantees that the Toyota version has the same heating system. I don't understand why you just don't get a proper one for the C1, rather than look for another non-C1 one that would fit it???
slackgarry
Because its not for the C1.
Kind regards
SlackGarry
perrye
(Donor 2026)
x 10
Unread post by perrye »
Can you search with the OE code? That should give you the right results, right?
x 1496
Mk 1 C1 is 6479A5, not listed as fitting anything else (well, except the 107!)
perrye
(Donor 2026)
x 10
slackgarry
Kind regards
SlackGarry
