Vin
super8
- Locked user account
Vin
Hi
Looking for more info about my DS7, wondering if someone could decode vin number
Vin - VR1**************[VIN obfuscated, can be read by forum staff]
Thank you,
Thank you,
local hookups with sexy women - https://privateladyescorts.com - adult chat with nearby women
super8
Re: Vin
Understood, thanks for replay, I was hoping to get some more info regaridng my car, DS Automobiles is a new brand in ireland and has only just opened its showroom last year, so to get any info from them is bit dificult.
When it comes to equipment versions, I have 19 reg 1.6 Purtech 180 in Rivoli, does this version have as standard DS Active Sacan Suspension?
- x 6945
Re: Vin
I can't be sure, you'll have to ask the dealer because the Rivoli was introduced at about this time.
For 2022 I know it was standard for the Rivoli & Opera models, specifically on PureTech 180 and PureTech 225 versions.
super8
Re: Vin
Thanks, would be any indication on dash board? when changing to comfort mode I can for sure feel diferent,
Sloppysod
- x 396
Re: Vin
Thought I'd add this as I didn't know what is was so had to "Google" it, well not Google (Bing) but same thing.
"DS ACTIVE SCAN SUSPENSION This intelligent suspension system uses a camera located at the top of the windscreen as well as several sensors to scan imperfections in the road in real time. It transmits this data in milliseconds to a computer which acts on each of the wheels independently."
Sounds clever
Any good?
Sounds clever
Any good?
Stu
super8
Re: Vin
Sure, but the question was whether the car is equipped with itSloppysod wrote: 17 Jan 2023, 14:18 Thought I'd add this as I didn't know what is was so had to "Google" it, well not Google (Bing) but same thing.
Sounds clever
Any good?
- x 6945
Re: Vin
I think it will have been for this model as it was part of the new line up from 2019 on.
Easy way to tell is if you have a 'DRIVE MODE' button present on the central console (next to ECO and SPORT ECO). This is the button you use to adjust the driving mode for everything including the suspension
super8
Re: Vin
I have Drive Mode button, so I can asume its equiped with
thanks help,
- x 2347
Re: Vin
I wondered what it was doing with the data sent to each wheel (and if was a new variant of Citroen's hydropneumatic)
https://www.theengineer.co.uk/content/i ... crossback/
(So not a potential source of bits to keep a hydropneumatic Citroen going then, oh well!
Can't help but wonder what the camera/ suspension would make of a lumpy grassed field? (I.e. with a multitude of visible things over 10mm high, but none having a bearing on what the wheels would run on!
Interesting stuff
Or "active damping"It uses a stereoscopic camera, mounted on the windscreen to scan the road for up to 20 metres ahead, identifying any irregularities of more than 10mm. This information – combined with a range of sensor data, including speed, acceleration and steering angle – is sent to a control unit that works out the optimum damper settings to mitigate the disturbance. A motorised solenoid valve on each damper is then used to adjust the flow of oil between the upper and lower chambers, giving individual control of both the bump and rebound responses on all four wheels
Interesting stuff
- x 6945
Re: Vin
It uses the following Matt:
4 Body height sensors
3 Accelerometer sensors
2 Front controlled shock absorbers
2 Rear controlled shock absorbers
1 Steering wheel angle sensor
1 Multifunction video camera
1 Variable damping control unit
These components are linked to a variable damping suspension computer and this in turn is linked to the BSI, the Engine ECU, the ESP system. On DS7 models with the sensory pack (forget the name now), selecting a driving style also changes the suspension characteristics.
It's not Hydropneumatic and isn't self-levelling as those days are truly gone with the X7
However despite being a slight
myself, it's truly scary what is on these DS7s to be honest in terms of tech and unless you have just robbed Fort Knox, or are Elon Musk, I wouldn't want the repair bills when any of the tech packs up!
- x 1055
Re: Vin
Firstly your vehicle has an outstanding quality campaign (not safety related) so contact your DS dealer about this.
Here is your spec from the VIN
Vehicle characteristics
Vehicle family DS 7 CROSSBACK (X74)
AS/RP N° 15436 88 1 1030
Warranty Start Date 15/03/2019
Engine serial number 10 FKA7 2528456
OPB 00CO
BER e2*2007/46*0601*05
P4A 9829137299
General information
PRODUCT TYPE PASSENGER CAR
COMMERCIAL MARQUE/COMPONENT TYPE DS
VEHICLE FAMILY DS 7 CROSSBACK (X74)
SILHOUETTE S.U.V.
TRIM LEVEL COMMERCIAL VEHICLE LEVEL 2 PSA
ENGINE EP6FADTXD 133 KW 1598 PETROL
TRANSMISSION STT TYPE 8-SPEED AUTOMATIC GEARBOX
PAINT TYPE THREE-LAYER PEARLESCENT METALLIC PAINT
BODY COLOUR KWE - PEARLESCENT WHITE PAINT
INTERIOR TRIM TYPE GRAINED LEATHER "57"
UPHOLSTERY COLOUR "FE"
GEARBOX (CHARACTERISTICS) ATNG8
CONVERSION GUIDANCE WITHOUT CONVERSION
DEFINITION TO FOLLOW INITIALE RANGE
ENGINE (TYPE) EP TYPE ENGINE
OTHER BADGE, " MISC. " RIVOLI VARIOUS ADDITIONAL BADGE
BADGE FAMILY BADGE
Fuel supply-Engine
FUEL SUPPLY DIRECT EXCHANGER TURBO INJECTION
FUEL FILLER CAP WITHOUT FUEL FILLER CAP
DIESEL FILTER WATER DETECTOR WITHOUT DIESEL FILTER WATER DETECTOR
FUEL UNLEADED PETROL 95 QUALITY A/B/E/E+
EMISSIONS STANDARD (ENGINE) EURO 6.2 ENGINE EMISSION CONTROL
SPEED SENSOR SIGNAL FRONT WHEEL SENSOR NON-SIGN RR SIGNED
CAPACITY 1600 CM3
FUEL TANK FUEL TANK WITHOUT LOCATING TAB
COOLING MOTOR RADIATOR EP28 28DM2 BRAZED ALUMINIUM
CRANKCASE GAS CIRCUIT HEATING WITH HEATER CASING GAS CIRCUIT
SPECIAL POWER TRAIN SOUND WITHOUT POWER TRAIN ACOUSTICS
EOBD SELF-DIAGNOSIS SYSTEM WITH "OBD" AUTO-DIAGNOSTICS
VEHICLE TECHNICAL DEPOLLUTION EURO 6.2 VEHICLE TECHNICAL EMISSION CONTROL
PARTICLE FILTER WITH PARTICLE EMISSION FILTER
FAN 1ELECT VARIABLE SPEED 180W AERO DYNAMIC FLAP
DRIVE TRAIN INTERNAL COMBUSTION DRIVE TRAIN
TANK FILTER RESERVOIR FILTER EXTERIOR
STOP AND START WITH STOP AND START STARTER
Gearbox Transmission
FINAL DRIVE RATIO REAR AXLE GEARSET 15 X 61
WHEEL STYLE STYLE5 20 INCH ALLOY WHEEL
CLUTCH WITHOUT CLUTCH
RIM/TYRE SIZE 20 INCH TYRE FIT
TYRE (SIZE, TYPE) TYRE 235/45 R20 100V NON-REINFORCED
DRIVING WHEELS 2 DRIVEN WHEELS
WHEEL (TYPE) ALLOY WHEEL ASSEMBLY 1
INFLATION PRESSURE LOSS INDICATOR INDIRECT DETECTION OF UNDER-INFLATION WITH LOCATION
GEARBOX TYPE ATN8 TYPE GEARBOX
Suspension-Steering-Brakes
REAR ANTI-ROLL BAR ANTI-ROLL BAR DIAM 19
FRONT ANTI-ROLL BAR FR ANTI-ROLL BAR STIFFNESS 30000 NM/RAD
BRAKE TYPE VENTILATED FRONT DISCS/REAR DISCS
STEERING WHEEL ANGLE WITH STEERING ANGLE SENSOR
SUSPENSION NORMAL SUSPENSION
DYNAMIC STABILITY CONTROL SYSTEM ELECTRONIC STABILITY PROGRAM
STEERING (OPERATION) HIGH POWER DOUBLE PINION ELECTRIC POWER STEERING
PEDAL BRACKET (TYPE) PEDAL ALUMINIUM
Body fittings
TOWBAR WITHOUT TOWBAR
HORNS HORNS-HARMONY
SIDE MOULDINGS (DIMENSION) THIN LATERAL/SIDE PROTECTORS+BODY SILL CHROMED DS
WHEEL EMBELLISHER (STYLE) BLACK CAP
EXHAUST TAILPIPE REAR RIGHT AND LEFT EXHAUST OUTLET
UNDERBODY SHIELD WITHOUT PROTECTION UNDER BODY
ADDITIONAL SHIELD (UNDER ENGINE) W/O ENGINE UNDERSHELDING
EXT. LOAD RETENTION RING (ATTACHMENT) BOAT EXT LASHING RING
EXT. REARVIEW MIRROR COMP. FUNCTION DRIVER ELEC FOLDING+PASSENGER+DIODE+REVERSE +MEMORY
EXHAUST TAILPIPE TRIM CHROME EXHAUST OUTLET TRIM
WINDSCREEN GLASS (TYPE) HEATED WINDSCREEN GLASS
WINDSCREEN WIPER FRONT WIPER BLADE WITH RAIN SENSOR
HEADLAMP WIPER W/O HEADLAMP WIPER
ROOF GLASS WITHOUT ROOF WINDOW
BUMPER BODY COLOUR FR BUMPER+GLOSS BLACK GRILLE+BODY COLOUR RR BUMPER+PAINTED BEAD
NUMBER PLATE WITHOUT LICENCE PLATE
FRONT FOGLAMP LED FOG LAMPS + CORNERING LAMP
PANORAMIC VISUAL AID WITH REAR PANORAMIC VISUAL ASSISTANCE VISIO PARK1
SPARE WHEEL SPACE-SAVING SPARE WHEEL
EXTERIOR ACCESSORIES CHROME+BODY-COLOURED EXT HANDLE
EXT. REAR VIEW MIRROR (DRIVER SIDE RADIUS) CURVED EXTERIOR MIRROR GLASS
BUMPER TRIM BUMPER WITHOUT TRIM
GLASS (APPEARANCE) TINTED + DARK-TINTED WINDOW GLASS
WINDOW (TYPE) ACOUSTIC LAMINATED WINDSCREEN + TOUGHENED REAR GLASS
HANDS FREE ACCESS AND STARTING WITH HANDS-FREE ACCESS/STARTING
Interior fittings
ANTI-THEFT ALARM VOLUME + PERIMETER + LIFT
CIGAR LIGHTER WITHOUT CIGAR-LIGHTER
REAR HEAD RESTRAINT REAR HEADREST ADJUSTABLE
FRONT HEAD RESTRAINT 4-WAY ADJUSTABLE FRONT HEAD RESTRAINT
REAR SEAT SEAT CUSHION+BACK 2/3-1/3 FOLDING
BLIND SPOT DETECTION ACTIVE BLIND SPOT MONITORING
REAR SEAT ARMREST WITH REAR SEAT ARMREST
CABIN SEAT WITHOUT CAB SEAT
LUGGAGE COVER SHELF
ASHTRAY WITHOUT ASHTRAY
CLIMATE (AMBIENT TEMP) HOT OR WIDER TEMPERATE COUNTRY
AIR CONDITIONING WITH HEATER MATRIX
SPEED GRADUATIONS SPEED GRADUATION IN KM/H
GEAR SELECTOR RAISED GEAR LEVER AT THE FLOOR + AT THE STEERING WHEEL
DRIVING POSITION RIGHT HAND DRIVE
ADDITIONAL HEATING WITHOUT ADDITIONNAL HEATING
MIRROR LINK WITH MIRROR LINK
LOAD SPACE LIGHTING LED STORAGE COMPARTMENT + GLOVE BOX LIGHTING
DASHBOARD EQUIPMENT LEATHER DECOR DASHBOARD
MISC. INT. LAMPS MONOCHROME AMBIENCE LED LIGHTING
INSTRUMENT PANEL (CHARACTERISTICS) DIGITAL INSTRUMENT PANEL 29 WARNING LAMPS
CHILD SEAT ANCHORING POINTS WITHOUT ANCHORAGE WITH ISOFIX FR AND RR
LOUDSPEAKER 4 FR SPEAKERS (2 TW + 2 FR)+2 RR SPEAKERS
ADDITIONAL BLOWER WITHOUT ADDITIONAL PULSE
POLLEN FILTER WITH POLLEN FILTER + ACTIVATED CARBON
FRONT PASSENGER SEAT HEIGHT CONTROL FRONT PASSENGER SEAT HEIGHT ADJUSTER ELECTRIC HEIGHT ADJUSTMENT+ELECTRIC FRONT SEAT CUSHION ANGLE
DRIVER SEAT CONTROL DRIVER’S SEAT WITH MEMORY CONTROL+CUSHION FRONT ADJUSTMENT
FRONT PASSENGER SEAT CONTROL PASSENGER’S FR ELEC SEAT CTRL + CUSHION FRONT ADJ
DRIVER SEAT ADJUSTMENT DRIVER’S SEAT TILTING BACK ELECPNE LUMBAR SUPPORT+MEMO
FRONT PASSENGER SEAT ADJUSTMENT TILTING SEAT BACK ELECTROPNEUMATIC LUMBAR SUPPORT+MEMO
FRONT SEAT ARMREST CENTRAL ARMREST FLOCKED + PVC
COMPACT DISC WITHOUT COMPACT DISC
SATELLITE NAVIGATION SYSTEM WITH NAVIGATION SYSTEM COLOUR SCREEN
HEADLAMP BULBS LED BULB
TRAFFIC INFORMATION READER PREVENTION+CORRECTION OF LATERAL TRAJECTORY
DISPLAY DGT TOUCHSCREEN+12" DFT DISPLAY
CLOCK ANALOGUE CLOCK
COURTESY MIRROR DRIVER+PASSENGER LED LIGHTING PASSENGER BLIND
FOOTREST ALU DRIVER’S FOOTREST
OIL GAUGE STD OIL LEVEL INDICATOR
HEATING ELEMENT DRIVER + R1 PASSENGER HEATED SEAT
FRONT LATERAL AIRBAG CHEST-PELVIS SIDE AIRBAG+RR CHEST+CURTAIN
FOOTWELL LIGHTING DRIVER + FR PASSENGER FOOTWELL LIGHTING
REAR PASSENGER PROTECTION W/O RR PASSENGER PROTECTION
AIRBAG DEACTIVATION MANUAL AIRBAG DEACTIVATION
HEADLAMP HEIGHT ADJUSTER AUTOMATIC HEADLAMP ADJUSTMENT
WIFI WITH WIFI
RADIO RECEIVER DIGITAL CONNECTED NAVIGATION
REFRIGERATION AUTOMATIC AIR CONDITIONING
CRUISE CONTROL REGULATOR AND SPEED LIMIT
DRIVER’S SEAT HEIGHT CONTROL ELECTRIC CONTRL DRIVERS HEIGHT ADJ
INTERIOR REAR VIEW MIRROR FRAMELESS INTERIOR ELECTROCHROMATIC MIRROR
CARPET COVER CARPET MAT 1
LOAD SPACE STORAGE RETRACTABLE FLOOR STORAGE COMPARTMENT
REAR SEAT PADDING WITHOUT RR PASSENGER DETECTION
TUNER RADIO TRI RADIO TUNER
OBSTACLE DETECTION SYSTEM FRONT-REAR RADAR OBSTACLE SENSOR
TRIM ADAPTATION LEATHER GEAR LEVER KNOB + LEATHER GAITER
FLOOR MAT FR + RR MATS
EQUALISER AMPLIFIER WITHOUT EQUALISER AMPLIFIER
RADIO FREQUENCY WESTERN EUROPE RADIO FREQUENCY
LOCKING CONTROL CENTRAL DEADLOCKING + AUTOMATIC LOCKING
STEERING WHEEL FULL GRAIN LEATHER STEERING WHEEL FULL 4-SPOKE
SEATING ASSOCIATED VARIANT VARIANT ASSOCIATED WITH HIGH SEAT POSITION
AUDIO PACK AUXILIARY SOCKET 3 USB PORTS
TELEMATIC UNIT INDEPENDENT TELEMATIC UNIT 3S
Electrical
ALTERNATOR ALTERNATOR 150 AMP
HORNS HORNS-HARMONY
BATTERY BATTERY L3 760 70AH EFR 760 EN EF
STARTER MOTOR STTD STARTER
CEN. LOCKING REM CONTROL FREQUENCY 433.92 MHZ SUPER HETERODYNE
ELECTRICAL EQUIPMENT (SUPPLY) STANDARD PROVISION ELECTRICAL EQUIPMENT
BATTERY CHARGER WITHOUT ON-BOARD CHARGER
MULTIPLEXING R3 ECO ELECTRICAL ARCHITECTURE
BATTERY CHARGE MEASUREMENT WITH BATTERY CHARGE MEASUREMENT
LIGHTING OF LAMPS AUTOMATIC SWITCHING ON OF THE LIGHTS+AUTOMATIC SWITCHING
Component manufacturers
Miscellaneous
SPECIAL SPECIFICATION STANDARD
ATMOSPHERIC CONDITIONS DUSTY ATMOSPHERE
VIN PLATE EUROPEAN UNION CONSTRUCTOR’S PLATE + NRE
LABEL WITHOUT LABEL
RADIO HEADPHONE SOCKET DOUBLE ACCESSORY SOCKET
SET OF KEYS SET OF BADGE KEYS + BACK-UP KEY
REFRIGERANT AIRCON FLUID 1234 YF
EMERGENCY EQUIPMENT W/O HELP EQUIPMENT
SURFACE CONDITIONS GOOD TERRAIN
EMERGENCY WARNING TRIANGLE WITH WARNING TRIANGLE
OPB 00CO
P4A 9829137299
General information
SILHOUETTE S.U.V.
BADGE FAMILY BADGE
Fuel supply-Engine
CAPACITY 1600 CM3
Body fittings
HORNS HORNS-HARMONY
Interior fittings
LUGGAGE COVER SHELF
WIFI WITH WIFI
Electrical
HORNS HORNS-HARMONY
Miscellaneous
LABEL WITHOUT LABEL
- x 6945
Re: Vin
Just modified controlled dampers but no hydractive with hydraulics like the X7 or C6.
I think the Audi TT used electronics to change the particles in the damper fluid to stiffen or soften the damper IIRC years ago.
super8
Re: Vin
Thank you for that information, I'm not realy sure what what you mean by ''outstanding quality campaign''wheeler wrote: 17 Jan 2023, 22:09 Firstly your vehicle has an outstanding quality campaign (not safety related) so contact your DS dealer about this.
