Hi
Has anyone any pointers on the removal of the fuse box that is located in the engine bay? Not an electrical problem, I need to access the suspension mount behind it in order to remove the strut.
The top bolt of the suspension is very well hidden behind the fuse box.
DS5 engine fuse box removal
Dannio636
Re: DS5 engine fuse box removal
Follow up.. turns out you dont have to remove the fuse box to get to the top mount..
Found I had a spring snapped.. replaced now.
