C3 Picasso Clutch Fault
Dormouse
- x 696
HI. A C3 Picasso HDI has a clutch pedal that has gone to the floor and stayed there. Is the most likely fault the master cylinder or is there anything else I should look for?
- x 1060
Re: C3 Picasso Clutch Fault
9 times out of 10 its the slave cylinder. Any sign of fluid leaking when someone operated the clutch pedal up & down?
Dormouse
- x 696
not looked yet. How bad a job is a slave cylinder change?
Huskyxantia
- x 928
Any updates ?
Husky.
Huskyxantia
- x 928
Slave is easy . Master too , it's just the bleeding of the system that's s pain in the arm
Husky.
