central locking
crooser
central locking
does anyone know where the central door locking control unit is on a 95 xm and what it looks like?
Nikolaymk
crooser
Russell
My guess is that the controller is in the drivers door.
I tried to find it in my XM, and deduced from older posts that it was in a door, and most likely to be in the passenger door. When I took the passenger door apart, I found no controller, but I did cure my doorlock problems anyway.
cheers
Russell [:)]
cheers
Russell [:)]
Russell
rabenson
couteau
My central locking module gave up on me on my series 1 XM. It is under the steering wheel (opposite side of fuse box). Mine is UK/left hand drive or is it right?. If you open that compartment, there will be another set of screws/bolts (12mm) which secure an aluminium/metal 'shelves'. The module is a longish one secured to that metal shelves.
Try locking/unlocking, then you can identify from the noise which box it is. Trouble is you won't find parts for it so I installed a Japanese alternative but took sometime to identify which wire is for what.
Good luck,
Charles
Good luck,
Charles
