Upgrade firmware
Citroen2018
- x 12
Upgrade firmware
Need som help.
I try to update the firmware and maps, getting this message; I have a 32 gb usb-stick (format FAT32)
"Version is not compatible with the hardware"
My current version:
31.08.05.86_NAC-r0
Suggested update which Ive downloaded via Citroen update:
42.03.33.42_NAC-r0
(23.2 GB. 2021-07-30)
My VIN-code:
Anyone have any ideas?
Thanks,
Need som help.
My current version:
31.08.05.86_NAC-r0
42.03.33.42_NAC-r0
My VIN-code:
Thanks,
- x 6945
Re: Upgrade firmware
Ok, as you don't have on-board WiFi (no telematic Unit) you may need to connect to your smartphone's WiFi in order to apply the update as the licence file is checked with the hardware of the telematics unit. So you need to be in a good WiFi coverage area, then use the connections setting on the Connected Nav Head Unit to connect to your phone. Wait until a connection is established and try the update again. The system tries to verify the licence over the internet with PSA servers. In most cases this is the issue with this message when you have the correct updates.
- x 1938
Reading elsewhere there's apparently a problem with the software. PSA are supposed to be working on a solution.
- x 1938
These are some of the posts regarding the problem.
Can't update firmware on any version of Nac, problems with certificates.
For now there is no solution, we are waiting for PSA to solve the problem.
This is an interesting post. It seems to offer a solution. Thanks to Tasmanian on gpspower.netFor wave 2, the new update of December 5 with new certificates is not yet available on the PSA servers, still the old one.
It is certainly in the testing phase, an old one from November which was supposed to correct the problem has never been deployed.
Customer effect
Message "Version incompatible with the Hardware" when updating Soft NAC Wave 4 (42.03.33.42_Nac-R0) , Wave 2 (21.08.87.32_Nac-R1) and RCE W1 (1.3.4)
Final solution > Packages have been updated. Redownload the entire package to complete the update.
Program for downloading the right Firmware and Maps for your Connect Nav (TomTom) !
Citroën Update:
For Windows: https://citroen-update.cppv2.awsmpsa.co ... 0.1.24.exe
For MAC: https://citroen-update.cppv2.awsmpsa.co ... Update.dmg
Peugeot Update
For Windows: https://fr.ndp.awsmpsa.com/majesticinst ... update.exe
For MAC: https://fr.ndp.awsmpsa.com/majesticinst ... update.dmg
OPEL Update
For Windows: https://my.opel.nl/downloads/map/instal ... update.exe
For MAC: https://my.opel.nl/downloads/map/instal ... update.dmg
DS Update
For Windows: https://map-update.dspp.awsmpsa.com/installer.exe
For MAC: https://map-update.dspp.awsmpsa.com/installer.dmg
Citroen2018
- x 12
That I think I havent tried, thanks for that. Ill try that and see what happens =)GiveMeABreak wrote: 22 Dec 2022, 13:41 Ok, as you don't have on-board WiFi (no telematic Unit) you may need to connect to your smartphone's WiFi in order to apply the update as the licence file is checked with the hardware of the telematics unit. So you need to be in a good WiFi coverage area, then use the connections setting on the Connected Nav Head Unit to connect to your phone. Wait until a connection is established and try the update again. The system tries to verify the licence over the internet with PSA servers. In most cases this is the issue with this message when you have the correct updates.
Citroen2018
- x 12
Im not sure but I think my version never been updated? Perhaps the gap is too big to the newest version. Is there somewhere to find older firmwares to upgrade the updates between my version and the latest?
- x 6945
No need, you can upgrade from any earlier version to the latest version.
Citroen2018
- x 12
So I've now tried this and unfortunately I get the same message.GiveMeABreak wrote: 22 Dec 2022, 13:41 Ok, as you don't have on-board WiFi (no telematic Unit) you may need to connect to your smartphone's WiFi in order to apply the update as the licence file is checked with the hardware of the telematics unit. So you need to be in a good WiFi coverage area, then use the connections setting on the Connected Nav Head Unit to connect to your phone. Wait until a connection is established and try the update again. The system tries to verify the licence over the internet with PSA servers. In most cases this is the issue with this message when you have the correct updates.
I've tried with 3 different USB-memories and have downloaded the filepackage two different times.
I'm out of ideas
- x 1938
Ermm...
Paul-R wrote: 22 Dec 2022, 16:32 Reading elsewhere there's apparently a problem with the software. PSA are supposed to be working on a solution.
Citroen2018
- x 12
In that case I guess there is nothing to do? But shouldn't more be writing about experiences that they cant update, if that's the case?
- x 1938
Did you try anything suggested in the same post by Tasmanian?
Otherwise it seems those afflicted will just have to wait.
Citroen2018
- x 12
Yes I tried that.Paul-R wrote: 26 Dec 2022, 21:46 Did you try anything suggested in the same post by Tasmanian?
Also tried with a 4th smaller USB-memory and removed the folder with maps, to only update firmware (5gig~). Then nothing happened at all. No error code and no update.
Tomas1
- x 11
For Nac Wave 3, you must use a firmware version downloaded after 12/23/2022.
Citroen2018
- x 12
What does that mean? I need to use the citroen update after 23/12 2022?Tomas1 wrote: 27 Dec 2022, 18:54 For Nac Wave 3, you must use a firmware version downloaded after 12/23/2022.
I downloaded the files like a week ago.
Tomas1
- x 11
Firmware downloaded after this date uses new certificates and there are no more problems with installation.
