Where is the throttle cable located on a 2010 2.0 HDI? The pedal sags and does not give full throttle
ty
Picasso throttle cable
kadaq
Grab yer cock and hit up this live sex site packed tighter than a dip can with filthy webcam models stroking, toying and screaming in free adult cams: indianlivesex
pantyhosecam
freeadultcam69
- x 1061
Re: Picasso throttle cable
It doesn't have a cable on this model, the pedal itself has a built in hall effect position sensor. If the pedal itself is faulty its a straightforward simple replacement, only usually 3 10mm nuts holding it on then unplug the electrical connector.
