Citroen DS5 and wierd problem with central locking
serenity20
Unread post by serenity20 »
Hello All
Excuse my bad language, but needs a little help.
I recently noticed that I have a problem with central locking, and now i don't know what its the reason.
When I turn off the ignition after about 5 minutes, the central locking does not work with the remote control, and when I turn it back on works normally.
looks like some mode eco.
what happened in the meantime:
1. I change the oryginal radio to china android (maybe i connect something wrong)
2. I have battery problem (eco mode and clock lose the data - in Poland we have a little winter and temperature -10*) - I charged the battery today and what i must to do? reset BSI - he has some battery memory?
I check parametrs and looks like that:
- 12,67 V when he OFF
- 12.1 V when light is ON
- 11 V when Start Engine
- 15V when Engine is Running
My Car is Citroen DS5 2012 163KM 2.0 ON
Plz for a little help.
x 1061
Re: Citroen DS5 and wierd problem with central locking
Unread post by wheeler »
serenity20 wrote: 19 Dec 2022, 19:59
1. I change the original radio to china android (maybe i connect something wrong)
I'd say this is almost certainly your problem. It will be one of 2 things, you have either blown a fuse when fitting the new radio or The Android radio is incorrectly fitted. Just because the connector may be the same does not mean it is plug & play. Disconnect the radio & see if everything will return to normal.
serenity20
wheeler wrote: 20 Dec 2022, 07:06
which fuse to check?
I connected everything that was there. I didn't know which antenna was for the radio.
is plug & play - before I bought this radio, two people fitted it to their cars. they don't have any problems.
serenity20
ok. I checked the errors in diagbox and what i have:
1. B1531 07 - audio/telematics buttons
2. U1F1A 87 - LIN network
3. B1836 00 - transponder antenna
4. B1003 00 - telecoding fault
maybe it will help
Redzo
Unread post by Redzo »
Hallo , problem solved?
I have some problem with peugeot 508 2013 after install new android radio from china?
Juston
Unread post by Juston »
Have tried a lot, does anyone have any solution for this problem
Juston
Hi I'm facing the same issue for my Citroen DS5 2014 model manual petrol, I'm central locking system is doesn't work after 5 minutes, only works when I open the with Handel, have any one anything regarding this issue. Please do let me know
x 1061
Have you changed the radio in the car or has anyone been touching fuses in the car just when the problem started?
Juston
Yes I have changed the radio to Android system, I checked with obd2 scanner, tried to reconnect the radio, still the same. After 5 minutes it goes to sleep. Can't use remote to open the car. Must manually open it with Handel sensor.
How to check the blown fuse and which fuse?
x 1061
Do you have the wiring diagram for the Android unit? The issue will be that there is wiring from your car that is connected to the android that is not supposed to be. Its very difficult to try to help with this without some sort of wiring diagram as they are all different. Just because the connector may look the same& it fits doesn't mean these are 'plug & play'. Often the wiring on the new unit may need to be modified to suit the car.
